ricoh sg3110dn HELP
Ben Brosnan
Re: ricoh sg3110dn HELP
Bought printer second hand, cant seem to download driver, my laptop windows vista????
Ben, as far as I'm aware, there is no driver for vista based systems, I could be wrong here but I've never seen the driver for vista based systems, you're probably better off either grabbing another os disk such as window 7 or 8 and installing it then the drivers should work.
Either that or use another pc that has a later windows version on board?
- InkExpress
As Paul said RICOH did not support VISTA, only Windows 7 or later OS appear to be available to download.
Alex
Alex
I used to run my 3110 fine on Vista before upgrading to Win7. However, the CD with my drivers doesn't seem to want to upload for some reason.
- InkExpress
I think the disc that came with the printers supported VISTA, but the downloaded drivers don't cover itwebtrekker;132957 wrote:I used to run my 3110 fine on Vista before upgrading to Win7. However, the CD with my drivers doesn't seem to want to upload for some reason.
Ben Brosnan
Its me again
back and thankfully got my new laptop today, windows 10. 64bit im told. Cant seem to find post where i was helped with what to do next. Need to download program for printer, is it PLC6 i go to??? sorry if im a pain
- InkExpress
http://support.ricoh.com/bb/html/dr_ut_ ... tm?lang=enBen Brosnan;133467 wrote:Its me againback and thankfully got my new laptop today, windows 10. 64bit im told. Cant seem to find post where i was helped with what to do next. Need to download program for printer, is it PLC6 i go to??? sorry if im a pain
Yes PLC-6 or raster driver (at the bottom) should be what you need. Sure I used to use the raster driver as it was full driver setup.
Alex
Ben Brosnan
Thanks for that. if i order ink from inkexpress will i get icc profile as well?? do i have to get ciss ink system??
- InkExpress
Hi Ben,
We will supply an ICC profile with our inks and you would need refillable cartridges for the Ricoh in order to use the ink.
We do a package of both, or you could purchase the RIC elsewhere and come back to us for the ink.
Whatever suits you best.
Kind regards,
Chrsitian
Kind regards,
Chrsitian
