Welcome to VBulletin!
- mrs maggot
Re: Welcome to VBulletin!
took a while but im in now - btw admin@dyesubforum.co.uk. needs the "." taking off after the co.uk otherwise people can't contact you from the forum
its that time of year 2 other forums i use have changed over to a diff package - must be somthing in the air
Justin;13327 wrote:Any update Paul?
so far so good
- mrs maggot
the link with the extra "." is on the front page of the site, where you have put if you are having problems contact.................
Welcome to the NEW DSF VBulletin Forum! If you have any issues with the new forum, please let me know by emailing admin@dyesubforum.co.uk.
Aha, I see. I hadn't realised it turned it into a direct mail link. Did you realise you can dismiss these notices when you've read them?
- mrs maggot
yeah, i use Vbulletin on another forum so i am pretty used to it
JSR;13316 wrote:Interesting change of forum software.
I'm sure I've just missed the setting, but where do I change the date format so it's not "12-22-2010"..? I'd like it to be DD-MM-YYYY as it should be.
Thanks!
Should be rectified now
Thanks for a great forum Justin, being new here I've not had a problem with it.
Chharlie
Chharlie
