Any tips for UV primer for metal and glass ?
Ravisteam
Re: Any tips for UV primer for metal and glass ?
Post by Ravisteam »
Ive bought a Mimaki 3042 FX uv ..configured to cmykww ..so primer need to be added manually ..any tips where to buy and stuff ??
Andysam26467
Post by Andysam26467 »
Ravisteam;134380 wrote:Ive bought a Mimaki 3042 FX uv ..configured to cmykww ..so primer need to be added manually ..any tips where to buy and stuff ??
Hi Ravi,
I’m not sure how to use primer manually. I use primer on most substrates as I find it helps bond the ink better and avoids scratching off. As a rule I use 60% primer set to valid pixels
Ricky@Xpres
Post by Ricky@Xpres »
Hello Ravi
This is a link to the Mimaki Primer https://www.xpres.co.uk/p-8771-sign-dig ... xpres.aspx
Just apply to the product with a lint free cloth and print the product within 24 hours.
Ricky
Xpres
Out of stock Ricky :-( Are you able to notify OP when this will be available again please?
Ricky@Xpres
Hi Justin
If you place an order for it today i can get it shipped direct from Hybrid for an extra £12.95 as they have stock.
Ricky
Xpres
Justin;134407 wrote:Out of stock Ricky :-( Are you able to notify OP when this will be available again please?
Ravisteam
Post by Ravisteam »
Ricky@Xpres;134406 wrote:Hello Ravi
Thanks Ricky ...
Ricky
Xpres
Thanks for the link Ricky ...When do u get the stocks ?.
