Blizzard Convection Oven Owners
Re: Blizzard Convection Oven Owners
Hi Guys
Those of you who own the Blizzard Convection oven will you share your times and dial settings so we can build up a good picture of what works best. Obviously there are variables but it would be good to get a starting point. I will share mine and tag those who I know have one.
I have only included mugs for now, but I please share anything else, once we have a good collection of items we could produce a new post with a definitive list...
Environment: I have business unit that has no heating. In winter months it does get quite cold and this does have an effect on printing due to the ceramics being considerably colder than normal. This generally adds about 2 minutes to the below times which are based on summer times.
My mug template is 92mm deep and 220 wide.
Always make sure your dye sub paper is wider (or longer if you like) than the mug wrap. Mine is almost touching the handle. I have found this prevents the blue hue which is common in ovens. I tend to have no bleed at the top and 1mm or less at the bottom. I have nothing at the top as I find that the ink can transfer to the inside top, reducing the amount at the bottom reduces the amount of ink that is transferred into a gas with no where to go (except places like the handle).
I clean my wraps about once a month. Ram the oven up to full and when hot chuck all the wraps in for 20 minutes ish.
"Light spots" will either be time or pressure. Increase the time and see what happens, but it might be time to replace the wraps.
1 Mug 7 minutes
6 Mugs 12 minutes
24 Mugs 16 minutes
1 Mug 7 minutes
6 Mugs 12 minutes
24 Mugs 16 minutes
My temperature is set the same, our timings for mugs,
1 Mug - GET THE PRESS OUT
3 Mugs - 10 Minutes
4 Mugs - 11 Minutes
6 Mugs - 12 Minutes
9 Mugs - 12 Minutes 30 secs
14 Mugs - 14 Minutes
17 Mugs - 16 Minutes
22 mugs - 18 Minutes
3 Mugs - 10 Minutes
4 Mugs - 11 Minutes
6 Mugs - 12 Minutes
Earl Smith
Very interesting.
It shows that an oven is only viable for quantities over 6 mugs. I have a twin press and can do 6 mugs in 12 mins. But really useful when doing large orders.
Don't forget the consistency of using the oven, top to bottom full wrap and printing closer to the handle.Earl Smith;136673 wrote:Very interesting.
I agree with Justin's comments tbh.It shows that an oven is only viable for quantities over 6 mugs. I have a twin press and can do 6 mugs in 12 mins. But really useful when doing large orders.
When I put a mug in the oven, regardless of how many it is and what the design is, I know it is going to print exactly as it should. I never look at how close it is to the handle, nor do I care if there is print bleeding off the top or the bottom. While I agree that there are some mug presses that can do that, I wonder how many operators can say with true conviction that they have 100% faith in their kit to consistently produce a mug that prints top and bottom and 220mm wide regardless of qty.
I 100% agree with you Earl in that there will be a few jobs where a mug press will probably be a better option, but in my very humble opinion, those jobs have too many restrictions (print area etc) and are too inconsistent.
Earl Smith
Mugs for me is only a side job and 1 to 2 % of my business. 80% embroidery and 18% printing t-shirts is what I do.
But a very interesting point , my mug press, the Adkins studio twin will only ( with confidence) do an 180x85 mm print. But when the whole area is printed I will turn the mug over and press again for another few mins to make sure the corners are done.
Don't forget to add your mug type, as mug wall thickness can introduce a variable. I'll get my oven up and running at the weekend hopefully.
I am only using a halogen at present, but comments seem quite good about this convection oven.
I have googled blizzard convection oven, is it the 33ltr one that people use.
And a good supplier please.
Gooner: Good point. My times and temp is for Listawood Duraglaz 10oz mug
Robhil, this is the one I have https://www.cs-catering-equipment.co.uk ... ction-oven
I ordered my 33l Blizzard from CEonline for £382 delivered.robhil;136701 wrote:I am only using a halogen at present, but comments seem quite good about this convection oven.
As I mentioned before I was really stuck for depth space on my worktops. The oven needs a 4 inch clearance from the wall for safety, so it will fit perfectly on a standard 2 ft depth kitchen worktop. Unless, like my studio, your electricity sockets and network cables sit in a plastic enclosure preventing your oven going anywhere. I'll have to turn my studio upside down this weekend to get this into place, hence the delay in getting the oven set up. Buy yourself a CO2 fire extinguisher.
