best sublimation ink?
darode
Re: best sublimation ink?
Post by darode »
Hi everyone, new to the forum, really would appreciate some help here. I'm struggling with results printing mugs, I have an Epson wf 2510 with sublimation ink and a Galaxy mug press pro v2 but cannot get decent images, the image is a black ink image and writing and it comes out with yellow around the image which I think means it's too hot so drop the temp by 5 degrees and it is faded. Could it be cheap ink or should I be using a certain transfer paper? What is the best ink and transfer paper for this combo? What do you think? Temp on the press is 150 degrees C for 120 seconds. Any help would be greatly appreciated.... I'm going through mugs like you wouldn't believe. Cheers everybody in advance.
What ink are you using and do you have profile installed?
darode
Post by darode »
Hi Justin, the ink is called fotorite and I got a package which included the profile set up from Cityink Express
Hi. Although I have a different printer (Ricoh SG3110DN), I use inks from CIE and my results are excellent.
You don't say what make of mugs you are printing on? Mug coatings make a tremendous difference.
Also, and I'm not dissing Epson here, but I have read many times about yellow casts from Epson printers. However, never having used them for sublimation, I can only suggest you wait for someone with more experience with these printers to reply.
darode
Post by darode »
The mugs are PixMax, also I am working in my garage, do you think humidity or cold will affect results? Cheers.
Mugs could be the issue, inks 'should' be ok. Temp can play a large factor in results, especially with papers etc. try to ensure there's always a background heat source keeping the chill/damp off.
darode
Post by darode »
Thanks Justin, what make of mugs and transfers would you recommend?
Plenty of discussions on here, personally I only use Xpres XP5013 10oz mugs. You'll see members also using Listawood mugs amongst others.
darode
Post by darode »
Thanks I appreciate it, What transfer paper would you recommend? Sorry to keep bombarding you.
Trupix for me and many others, Ink Express do a good paper as well so check them out (remember your discount) Xpres have a good budget paper.
