Banding
Quinsfan
Re: Banding
Post by Quinsfan »
Old Ricoh, Dye Sublimation Supplies sublisplash ink and new paper from Ink Experts. All through the Sublisplash Driver supplied by Dye Sublimation Supplies.
Seriously bad banding but clear nozzles.
Any ideas?
Quinsfan
Re: Banding
Post by Quinsfan »
This is with the setting now set to high quality
Re: Banding
Is there a head alignment feature on your printer?
Quinsfan
Re: Banding
Post by Quinsfan »
Re: Banding
Was there much change required in alignment?
Quinsfan
Re: Banding
Post by Quinsfan »
Have adjusted still same result
Re: Banding
Which model printer? Does it have the power flush feature?
Quinsfan
Re: Banding
Post by Quinsfan »
The Ricoh 3110
Quinsfan
Re: Banding
Post by Quinsfan »
Test print from the machine
InkExperts
Re: Banding
Post by InkExperts »
This issue looks like it may be the 'dithering' issue. I can't recall the exact cause or fix but I am fairly confident it was a driver / software issue causing the printer / printing head to dither whilst printing.
When I use my SG3110DN I will usually set the paper type to Glossy and Quality Priority, I use the standard driver rather then Powerdriver or the Sublisplash one. I may be worth trying to printing using the standard driver to see if this resolves the issue?
Alex
Users browsing this forum: Amazon [Bot], Google [Bot] and 6 guests
