SubliBoard Cut to Size/Shape
Re: SubliBoard Cut to Size/Shape
... what you can do is to add a layer of clear varnish to seal it in though ... and then the next experiment is to heat press the varnish layer, as often this will be poly based and sublimate the colours beneath it and make the colours more intense rather than washed out.
