dark t-shirts
danlad
Re: dark t-shirts
Post by danlad »
What is weeding?
NASH
Re: dark t-shirts
Post by NASH »
removing all the unwanted parts of text which is not required
AdamB
Re: dark t-shirts
Post by AdamB »
danlad
Re: dark t-shirts
Post by danlad »
I've been watching some videos on YouTube about craft robo. People are printing images then using the cutter to cut the images out. How does this work?
What printer do you need to do that, is it only laser?
What media do you print onto then cut out?
What are the end results like?
Does it wash well, does it crack or fade etc.?
smitch6
Re: dark t-shirts
Post by smitch6 »
so basically the best way to print onto dark T's is by doing it in vinyl with a robo cutter thing for around £200
and is the quality good and does it last in the wash etc
i've just had someone ask me to sort them some dark T's out for work
so there would be yellow text and then the coloured logo
i have looked on BMS webby and that craft robocutter looks small and compact
but is that just a cutter???? and does it work with a mac :~
i'm not sure how this vinyl stuff works sorry
danlad
Re: dark t-shirts
Post by danlad »
That's what I'm trying to work out. I've seen some good vids on YouTube and it seems a good little machine. I don't understand the way the printing side of it works and what the life span is of a finished product is.
smitch6
Re: dark t-shirts
Post by smitch6 »
yes its either vinyl or direct to garment print which is what i'm now searching for on google
danlad
Re: dark t-shirts
Post by danlad »
After more reading it looks like there is no real easy solution to dark t's!
Re: dark t-shirts
danlad;14409 wrote:After more reading it looks like there is no real easy solution to dark t's!
there is. flex, flock, printable vinyl as subli flock and flex and if you want to do photo quality the DTG is the way to go.
so there is loads to chose from. All of them cost a bit. DTG is :) but this is good i think. coz if every one would afford it then there would not be any room for another business :)
smitch6
Re: dark t-shirts
Post by smitch6 »
i looked at BMS's DTg packages and they look good
but kinda outa my price range at the minute
do second hand ones come up very often
what is the flock, flex etc
i looked at them too but was a bit confused (which isn't hard) lol
