Hi all,
Just a quick one; do any of you use direct debit software for any of your clients?
We've a few clients that like to build invoices up with late payments, and getting to the stage that cash-flow is getting affected. Have had a quick Google and seems to be a few recommended subscription ones that could be of use, but thought would ask the professional heads on here before jumping into to sorting something out.
Direct Debit Software
bubbleimages
Re: Direct Debit Software
Square can be used to set up regular charges on cards if you are already using them for contactless payments.
https://squareup.com/gb/en/townsquare/h ... g-payments
bubbleimages
- mrs maggot
I Use go cardless, it is now integrated into my Quickfile book keeping system, works well.
bubbleimages
Thanks Mrs Maggot,
Will look at that, as it seems to integrate with FreeAgent also which is what we use for business. Thanks again.
- mnporter2001
For DD I use GoCardless, for everything else I use Stripe or if I must and the customer requests it I will use Paypal.
I also note that Stripe are doing DD's now but cant be arsed moving customers from GoCardless.
Hope that helps
Mark
Hope that helps
Mark
Custom Gifts www.mugsaway.co.uk <--- A work in progress!
