Heat press
W3sty3oy
Re: Heat press
Post by W3sty3oy »
Hey guys, looking to purchase a decent heat press just brought a Epsom p800 and looking for a press to match any recommendations.
Even better has anyone got anything for sale ?
I've looked through and seen lots of good stuff been looking a t pressmech I know a few favour that here.
What is magic touch like?
Any other brands worth looking at or links to one for sale I need something a3 size.
W3sty3oy
Re: Heat press
Post by W3sty3oy »
I've found a used magic touch 297mm X 420mm looks old £250 would anyone recommend?
Re: Heat press
Most Magic Touch machines are rebranded Adkins which are considered one of the better makes.
In general you can't go wrong with an Adkins or a Pressmech as both have excellent reputations.
W3sty3oy
Re: Heat press
Post by W3sty3oy »
Is there anyway I can check it is a sound bit of equipment? or do they just not go wrong really?
Re: Heat press
Do you have an image of the machine? If you can see it powered up that would be a start. You need to check the heat across the platen to be 100% sure.
W3sty3oy
Re: Heat press
Post by W3sty3oy »
[ATTACH=CONFIG]6264[/ATTACH]
The guy picked it up from a job but doesn't know much about it what's it worth or should I wait and find another he said it's about 2008
vB_ID:6264
vB_ID:6264
W3sty3oy
Re: Heat press
Post by W3sty3oy »
I have about £500 to spend, I have been looking for best value for money and a good reliable press.
I have been looking through the website forum and found the reliable presses just trying to find one i'm thinkng a swing away needs to be a3 to work with the prints of the p800.
Thanks again for your help, I bet you have so many posts on here like this but I have been doing some research
Re: Heat press
It's the newer press (dark grey upper platen) which are built in China not Leicester but are still very good. At that price if it works ok it's a bargain.
For £500 I would expect an Adkins or Pressmech second hand.
Make him a cheeky offer and if it needs anything it would still be worth it ;-)
Re: Heat press
If you don't want it, Ill have it ;-)
W3sty3oy
Re: Heat press
Post by W3sty3oy »
got it for £200 seems to work well, equal temp across the plate, Is there a certain way to set these up with the pressure adjustment ?
Also anyone know of a good press for mugs and drink bottles please?
