mug sublimation woes - need advice
xlr8r
Re: mug sublimation woes - need advice
Post by xlr8r »
Hi guys
hoping someone can point me in the right direction here.
Im having issues with some of the ink not coming off the paper onto the mug.
In most places its fine, in others ... not so good (as you can see from the pic (12mb)
On the left mug i had temp at 200c for 240secs and the right mug at 205c for 300secs.
The left mug did print the majority of the ink onto the mug (except for the words "he" and "the", and text is slightly bleeding out.
The right mug had lots of missing ink transfer but had better colours and a sharper image....
any suggestions would be greatly appreciated on rectifying the problem.
Using a Chinese heat press
A-sub sublimation paper
Epson ET-2750 and Inktec Sublinova inks
thanks
mnporter2001
Post by mnporter2001 »
I'm no expert and am still learning myself but 240secs and 300secs seems a little long to me, what mugs are you using ?
Custom Gifts www.mugsaway.co.uk <--- A work in progress!
xlr8r
Post by xlr8r »
hi
theyre Orca coating 11oz Mugs from MDP
mnporter2001
Ok I have those and I press at 190 for 180 seconds.
That may or may not solve the issue, as I say I'm pretty new to this also but perhaps worth having a go at that temp and time.
Mark
ad832
Post by ad832 »
What software are you using? I use Circut to make my designs and when printing make sure the 'Bleed' option is off. then temp 205, time 200mins.
Are the mugs 'A' or 'AAA' quality?
StellaD
Post by StellaD »
I notice that they are quite narrow diameter mugs and need a different press element to the more popular models.
Are you using the correct element?
xlr8r
Post by xlr8r »
mnporter2001;145471 wrote:Ok I have those and I press at 190 for 180 seconds.
Mark
ill give it a try thanks
xlr8r
Post by xlr8r »
ad832;145472 wrote:What software are you using? I use Circut to make my designs and when printing make sure the 'Bleed' option is off. then temp 205, time 200mins.
i use photoshop for everything, "200mins" seems excessive ?
the mugs are listed here :- https://www.mdpsupplies.co.uk/dye-subli ... ation_mugs as "Premium Grade".
xlr8r
Post by xlr8r »
StellaD;145474 wrote:I notice that they are quite narrow diameter mugs and need a different press element to the more popular models.
the mugs are listed on MDP as ; Case of 36 premium grade Orca Coated 11 Oz Standard mugs. Dishwasher proof. 95mm high x 80mm diameter. Use Mug Element C.
im using (the recommended) element C
in terms of pressure, what is deemed as being "medium/high" ? is that when pressing handle in, is it a hard push to lock in ?
StellaD
Post by StellaD »
xlr8r;145477 wrote:the mugs are listed on MDP as ; Case of 36 premium grade Orca Coated 11 Oz Standard mugs. Dishwasher proof. 95mm high x 80mm diameter. Use Mug Element C.
OK,
In your earlier post you said they were "Chester" mugs which are 70 mm diameter.
theyre Orca coating 11oz Chester Mugs from MDP
Pressure wise you should probably have them tight enough to not be able to shift the handle of the mug when the press is closed but not too over tight.
