White marks on mugs
leehilton90
Re: White marks on mugs
Post by leehilton90 »
I am having this issue on almost every mug in different places mostly along the bottom. I am unsure if this is the mugs or the machine. If it was the machine I would have thought it would be in the same place every time?[ATTACH=CONFIG]6718[/ATTACH]
[ATTACH=CONFIG]6719[/ATTACH]
vB_ID:6718
vB_ID:6718
vB_ID:6719
vB_ID:6719
Are the marks visible prior to printing?
Mrteajunkie
Been thanked: 3 times
Post by Mrteajunkie »
It looks to me like a chip in the coating And it hasn’t taken the sublimation.
that’s why the mugs still white and the dark patch on the paper.
I have had this after the mugs were thrown around in transit.
leehilton90
I am not sure if it is visible, not without close inspection anyway. This has been a lot over the space of different boxes and deliveries.
Mrteajunkie
Are all the mugs from he same supplier?
Seems obvious to me that the deep pink/red mark on your print exactly coincides with the white problem area on the mug.
What printer, inks and paper are you using? What press?
webtrekker;148698 wrote:Seems obvious to me that the deep pink/red mark on your print exactly coincides with the white problem area on the mug.
I assumed this was the transfer after printing?
Justin;148699 wrote:I assumed this was the transfer after printing?
Ah yes, you're probably right Justin. I just wish posters would give more information to help solve their problems.
Mrteajunkie
Surely it would be noticeable on the print before pressing if it was the printer or media?
leehilton90;148687 wrote:I am having this issue on almost every mug in different places mostly along the bottom. I am unsure if this is the mugs or the machine. If it was the machine I would have thought it would be in the same place every time?[ATTACH=CONFIG]6718[/ATTACH]
Ok, please answer this: Was that second image (of the paper print) taken BEFORE or AFTER pressing? Thank you.
