- A decent amount of compression and bendability to it
- Whilst also being able to with stand 200 degrees C
- And sooth with zero tack so the hoodie will glide on
Heat Press pad material help
Re: Heat Press pad material help
I’m sublimating a hoodie that requires thread on to the lower platen for best results. The issue I am having is the that rubber material is to grippy and thus it a pain to thread the hoodie. Does anyone know of a material that has:
- Mrteajunkie
- Has thanked: 6 times
- Been thanked: 3 times
Target transfers sell covers for both the bottom and top platens. I have a lower cover on one of my heat presses and that really helps with this sort of thing.
as Simon said - Target transfer is your friend
[ATTACH=CONFIG]6823[/ATTACH]
- vB_ID:6823
- 4CFC8DEB-2204-4D85-907E-60FD23169804.jpg (31.11 KiB) Viewed 194 times
