Crenex 5 in 1
chris692424
Re: Crenex 5 in 1
Post by chris692424 »
Hi, I'm a newbie, and just bought a 2nd hand Crenex 5 in 1. Unfortunately it didn't arrive with any instructions. Does anybody have them and could scan them for me? thanks.
Mrteajunkie
Been thanked: 3 times
Re: Crenex 5 in 1
Post by Mrteajunkie »
There’s not really any instructions as such.
it’s all about time and temps different substrates require different settings.
What are you pressing?
chris692424
Re: Crenex 5 in 1
Just pressing coasters, key chains and car coasters initially. There are no instructions on how to set the temp, time etc. I've managed to figure out partly, but the timer isn't counting down, so doing something wrong.
Mrteajunkie
Re: Crenex 5 in 1
There should be a button on the unit to start the timer.
So you would close the press after it has reached temperature and press the button to start the timer.
post a picture of the control unit and we can advise further.
chris692424
Re: Crenex 5 in 1
OK Will do later this afternoon. thank you.
chris692424
Re: Crenex 5 in 1
[ATTACH=CONFIG]7027[/ATTACH]
Here's a photo of the control unit.
vB_ID:7027
vB_ID:7027
pw66
Re: Crenex 5 in 1
Post by pw66 »
If it is like most other controllers-
Press the set button - the temp should start flashing
Adjust temp with the arrows
Press the set button again and the time should start flashing
Adjust time
Press set button and both time and temp should be set.
If you only want to adjust one or the orher setting you still have to go through the whole process. Basically keep pressing the set button until everything stops flashing.
chris692424
Re: Crenex 5 in 1
OK thank you. I've managed it today but was getting confused lol. thanks again
