Incorrect Colours
Nic_Sparkles
Re: Incorrect Colours
Post by Nic_Sparkles »
Please help!
I am using an Epson SC-F100, its always been great but for some reason my colours are not printing correctly. Last week I printed something and the blue was very pale, almost grey and for the last two days I have been trying to print gold and it is coming out bright yellow. I have done nothing different and the gold is the exact same hex code colour that has previously printed perfectly. Can anyone please help as after 2 days of wasted materials, i could cry!
Thanks in advance
Mrteajunkie
Been thanked: 3 times
Post by Mrteajunkie »
Have you accidentally changed the settings in the print options.
What are you printing from? Photoshop, AI or some thing else?
Nic_Sparkles
Mrteajunkie;151557 wrote:Have you accidentally changed the settings in the print options.
I’ve tried Affinity and Gimp. I’ve checked the settings but as far as I know I’ve not done anything to them.
pw66
Post by pw66 »
Is your source artwork saved as CMYK? It needs to be RGB before you print.
Nic_Sparkles
pw66;151559 wrote:Is your source artwork saved as CMYK? It needs to be RGB before you print.
How would I even know that? It’s a logo from Canva
pw66
Post by pw66 »
In Affinity click on the 'Document setup' tab and in the pop-up click on the colour tab. Make sure one of the RGB options is selected.
[ATTACH=CONFIG]7028[/ATTACH]
vB_ID:7028
vB_ID:7028
Screenshot (75).jpg (14.38 KiB) Viewed 383 times
Nic_Sparkles
pw66;151561 wrote:In Affinity click on the 'Document setup' tab and in the pop-up click on the colour tab. Make sure one of the RGB options is selected.
I have just checked that and its RGB/8 still
Have you performed a nozzle check?
Nic_Sparkles
webtrekker;151566 wrote:Have you performed a nozzle check?
yes, I’ve done every check possible. I’ve spoken to Epson today and they are trying to blame the paper that I’m using and have always used. I don’t accept that at all so I’m still stuck with an order I need to get out and no printer to make that happen! 😭
