Text very faint
Re: Text very faint
Hi all;
If you look at the mug I've just printed and the image I used, you will see that the text at the top is very faint.
Does anybody know why this is, also the red is a lot brighter than the actual image and his skin has a different tone
I print directly from Photoshop and let photoshop do the colour handling.
Thank you
[ATTACH=CONFIG]7030[/ATTACH]
[ATTACH=CONFIG]7031[/ATTACH]
Thank you
- vB_ID:7031
- clough.jpg (12.42 KiB) Viewed 367 times
- vB_ID:7030
- Clough OBE mug-template.jpg (21.53 KiB) Viewed 367 times
Re: Text very faint
Thanks for responding, could you help a little further please and explain wha I need to do.
Re: Text very faint
What printer and inks are you using? Your supplier should have provided an ICC profile to allow you the correctly print the correct colours.
Re: Text very faint
The printer I have is an ET14000 and using Sublisure ink, I did ask Ink Experts if I need to use their ICC profiles and they said not really if I'm just doing mugs. Is this incorrect?
Re: Text very faint
The label says Sublisure and they came with the printer
[ATTACH=CONFIG]7032[/ATTACH]
- vB_ID:7032
- inks.jpg (7.55 KiB) Viewed 367 times
Re: Text very faint
No need to apolagise at all, I've noticed they do have ICC profiles on their site, will see if they make any difference.
Users browsing this forum: Google [Bot] and 3 guests
