Blue High Temperature Heat Tape 2cm x 66m
Help in finding new products.
Re: Blue High Temperature Heat Tape 2cm x 66m
Usually get this from SubliBlanks but out of stock, Neil Bros do it very cheap....but I don't really want to spend £300 to get it lol (Minimum order)
Anyone know any other suppliers? Must be 2cm x 66cm
Post by GoonerGary »
I was about to order 10 rolls. Is it showing 'in stock' on the website, but they've no actual stock after you ordered?
I've tried looking for that tape elsewhere with no luck. The Xpres tape is ok, but tricky to cut.
I checked with them but they don't know when it'll be in.
I've ordered some.off Amazon to see if it's the same, same size but not sure if it will be as thick which I need.
Will update Monday when it arrives.
Mrteajunkie
Been thanked: 3 times
Post by Mrteajunkie »
They sell it here. https://afac.co.uk/product/high-tempera ... king-tape/
but it’s £5.29 a roll.
Called polyester tape on there.
Yes not normally cheap but at 66m it's twice the length of most tapes so works out well.
Paid £9.99 for 4 rolls on Amazon so fingers crossed it's ok.
Appreciate the link.
Mrteajunkie;153264 wrote:They sell it here. https://afac.co.uk/product/high-tempera ... king-tape/
£2.65 plus vat for 10mm, but it's a £100 minimum spend. And there's a possibility it could be the same as the MDP tape.
Justin;153260 wrote:I checked with them but they don't know when it'll be in.
How did you get on with that Amazon tape? Any staining on mugs?
Apologies, not had a chance to update. Tape isn't as thick as the Subli stuff but it's working fine for what we need. It's a higher tack but isn't leaving any stains so fingers crossed all is good :-)
Have you got a link for the Amazon tape? Subliblanks didn't give a date for their tape.
