Rubbish mugs
pcwizme
Re: Rubbish mugs
Post by pcwizme »
I have used the same mugs and paper as you and not had an issue, I use either a dedicated mug press or an oven and not had that issue so .... I would lean it towards being the press, the problem with all in ones they don't always get even heating and often issues with pressure.
Lollipop
Re: Rubbish mugs
Post by Lollipop »
Thank you all for your help. It’s been confirmed this morning that’s definitely the press. Thanks ukprintedmugs, I really do appreciate it
Re: Rubbish mugs
Thanks for updating, great to hear you've isolated the issue. Thx also to UK Mugs ;-)
Lollipop
Re: Rubbish mugs
Post by Lollipop »
[ATTACH=CONFIG]7295[/ATTACH][ATTACH=CONFIG]7296[/ATTACH]
Proper mug has arrived and is absolutely fine !
vB_ID:7296
vB_ID:7296
Lollipop Crafts (8 of 22).jpg (32.68 KiB) Viewed 224 times
vB_ID:7295
vB_ID:7295
Lollipop Crafts (2 of 22).jpg (37.15 KiB) Viewed 224 times
