coaster box
Re: coaster box
does anyone know who sells little boxes that hold 4 or 6 coasters??
preferably with a clear lid
swimwivsquid
Re: coaster box
Listawood sells a cardboard box that holds six unisub coasters http://www.listawoodtradesupplies.co.uk ... roduct=460
Re: coaster box
I have some of those Listawood boxes here. They would hold about 10 normal coasters (of the non-unisub type) but the trouble is that the box is so much bigger (11cm sq) than the normal coasters (9cm sq) so they just kind of flop about inside the box. If it's unisub ones you're selling, then they're probably ideal. If not, then not.
Re: coaster box
I used to have some that were perfect for 4 x 9cm coasters plus the holder, I think they were through the Bag N' Box Man but I'll try and find out. A lot of companies around that will make small quantities bespoke, eBay etc. Always fancied having a go myself but never got around to making the template.
swimwivsquid
swimwivsquid
Re: coaster box
smitch6;16382 wrote:i haven't got a cutter lol
I thought every boat had one as standard fitting
Re: coaster box
Here we go....a very un-original box knocked up in 10 minutes, need to change dimensions...use thicker card....get the cutter to do the work for me
[ATTACH=CONFIG]113[/ATTACH]
- vB_ID:113
- box1.jpg (12.42 KiB) Viewed 406 times
- box1.jpg (12.48 KiB) Viewed 406 times
