CIS Ink
Davey
Re: CIS Ink
Post by Davey »
im new to sublimating and just wondering does ink evaperate
im using a sawgrass cis and it seems to be going down even when im not using it
i leave the little rubber bungs open all the time and even over night willm this effect it
help please:confused:
Re: CIS Ink
It won't evaporate unless you are in a very warm environment. Every time you switch your computer on (assuming the printer is on as well) then you will get a quick priming of the cartridges taking place which will use some ink.
