Epson stylus SX215
avfcvillan
Re: Epson stylus SX215
Post by avfcvillan »
Hi there here goes with my first NOVICE question.
I have brought a Epson Stylus SX215 with refillable ink cartridges (CMYB)
I purchased Visi-sub ink.
I will be using Photoshop CS3.
What will I need to do to my images to make the colours come out correctly?:confused:
Neil.
John G
Post by John G »
A profile to match your printer - not sure if your chosen epson has a profile though or is supported.
Matt Quinn
Post by Matt Quinn »
Basically you'll probably need to have someone make a colour profile for your set up... That or use 'Maxwell's triangle' or a similar technique to do it by eye. All things considered a proper profile is the better way to go.
Have you tried the set up though? Is it a million miles away from being OK?
avfcvillan
TBH i haven't tried it yet as i was trying to get everything that I possibly could in place before i took the plunge and tried the first mug. Also i'm still getting my head around photoshop, may have to ask my 17yo daughter to help with that one!
Visi-Sub (also known as Artainium) will have profiles made for it, but not for the SX415 though.
avfcvillan
I bought the ink from love cut but they don't seem to be listed on the reseller list I was going to try the d120 profile. Have I made a big mistake buying from where I did and where do I go from here. I'm going to try a trial run tomorrow evening ..
Matt Quinn
Trial run would be the first step to see how much work is needed IMHO... You MAY find as I did (with a 415 as opposed to a 215) that very little adjustment is needed.
It's worth mentioning that ANY off-the-shelf profile is only an approximation... Even if it's meant for the model of printer and brand of ink. The substrate you're going onto plays a part. As does the individual printer etc... Ultimately, if you were being really fussy, a custom profile is the way to go - How necessary that really is though depends on how far out of the ball park you are and what results you expect and/or demand.
I think one of the factors that needs to be faced is that any of us coming into this as novices have a bit of 'frog kissing' to do - experiment is an investment that needs to be made as much as the actual kit is.
avfcvillan;24892 wrote:I bought the ink from love cut but they don't seem to be listed on the reseller list I was going to try the d120 profile. Have I made a big mistake buying from where I did and where do I go from here. I'm going to try a trial run tomorrow evening ..
Lovecut are not licensed to sell sublimation ink so they shouldn't be selling any sublimation ink at all.
avfcvillan
Had I known this I wouldn't have bought from them but this is now where I am so i'll try some experimenting and when I come to resupply i'll definitely
know better
What's confusing is that VisiSub ink is a licensed ink from Sawgrass so they must have a source for this ink. There's nothing wrong with VisiSub ink as it is just new brand name someone is trying to create for Artainiun ink.
