full sublimation set up, ready to go.
Re: full sublimation set up, ready to go.
FOR SALE:
1x RICOH GXe3300N sublimation printer. Only used to run 2 small jobs, still has a small amount of cyan, magenta and yellow ink left and just under half a cartridge of black. Comes with all disks, all leads and instruction manual. Still have orriginal packaging.
1x flat bed heat press. Print area size 38cm x 38cm. Has built in timer up to 60 seconds and plays a tune when timer is up. Adjustable temp up to 399 degrees c, Adjustable pressure, temp display. Comes with 38cm x 38cm rubber heatproof mat. This press is a couple of years old but is still in perfect condition, I have no idea of the make but its from china like most of them!
1x Single mug press. This press is brand new and has only printed 4 mugs in its life! It has adjustable pressure, adjustable timer up to 999 seconds. countdown timer display and again, plays that all too familliar tune when countdown has finnished! This is a cheap press to be honest, it does not have adjustable temperature and is set as standard to the right temp to press mugs, moneyboxes etc. It does however, produce a better print than my much more expensive models! Would be perfect for smaller operations as it takes up hardly any space. Again, not sure on the make but is from china.
1x A4 paper trimmer 34cm wide.Brand new. Ideal for cutting transfers without getting fingerprints on them.
4x silicone mug wraps. These are not the £25 wraps that you will have seen before. they are a single sheet of silicone streched between to metal end pieces with clips to do them up. These are absolutely excellent at maintaining an even pressure around the mug and make it possible to sublimate top to bottom on the mug in any home oven. The company I work for uses hundreds of these wraps every day producing thousands of mugs and have never had any problems.
1x box of A4 sublimation paper. Perfect for use with the ricoh GXe3300N, brand new and un opened.
A few odds and sods I have laying about, a few mugs, mousemats, bar runners etc. couple of rolls of tape and any other bits I may find!
I am selling all this as I just don't have the time anymore! I'm looking for about £250 but am open to offers. will consider splitting if I can't sell it as a package.
pick up from oxfordshire or buyer to arrange courier. If you would like me to show you how to set up and use all this gear I will be glad to help.
Cheers.
Cheers.
Good price for someone to get started. Don't be put off by the small amount of ink left in the cartridges as the first set uses quite a bit filling the tubes, so this together with a new set will last ages.
wow!!! price is great in did!!! whats the prices like if you split??? I need a heat press...
for just the heat press im looking for around the £120 mark.
I think if you post some pictures it may sell quicker
just a tip
dj_doubler
@Paul.... I got my eye on that press :-p hopefully gonna arrange to sort something out
Having problems uploading photo's for some reason. If anybody would like photos of any of the kit just drop me a pm and i'll be happy to email you some. Cheers.
dj_doubler
dj_doubler - have just emailed you some pics, have you not received them?
If you want me to post the pics email them to justin@dyesubforum.co.uk
