Hi again!
One of you guys mentioned setting up an ICM profile for my workforce 30 Epson. I set it up the way it showed me on some site, but it made no difference at all.
The blotching and Bleeding through the paper is still happening.
can someone walk me through the ICM set up?
Also how can I adjust the amount of ink going through the nozzle?
Need help setting up an ICM profile
Re: Need help setting up an ICM profile
Can you supply a bit more information please?
Are you using an EasyFlow ink system or refilling your own cartridges?
If you're using an Easyflow system there will be a CD full of pdf support documents - have you had a look at these as they show how to set the profile, what settings to use in your graphics package etc.
You can reduce the volume of ink going through the nozzle by changing the print quality from best quality to a lower setting.
