YELLOW CAST
BobC
Re: YELLOW CAST
Post by BobC »
Just switched on my new mug press yesterday and I'm getting a lot of rejects.
Several questions........
Does anyone have notes on printing from Indesign or PDFs ?
I prefer to do my designs in Indesign rather than Photoshop. However when I started getting bad colour I imported into PS and followed the Artanium instructions closely. I am getting a yellow cast on a full colour photograph.
I have a very good graphic calibrated monitor and have a screen match for the PS and Indesign windows.
I'm printing on an epson 1400
Any suggestions?
Bob
Re: YELLOW CAST
I have one sugestion :) Is your pdf software or Indesign able to work with ICC profile?? if not I am affraid you need to use PS or coreldraw or similar software whitch can use Icc profiles.
BobC
Re: YELLOW CAST
Post by BobC »
Dear Paul
PDF files and Indesign are probably the two most common trade users of ICC profiles.
Bob
BobC
Re: YELLOW CAST
Post by BobC »
Dear Paul
http://en.wikipedia.org/wiki/Portable_Document_Format
I have a lot of experience with graphic programmes and PDF files. They really are more foolproof for most applications than a photoshop file which requires all those layers to deal with text and borders.
However, I have since done a few more tests and seem to be stuck with the yellow cast problem. On looking closely at other images it seems more like a lack of cyan. Images with a warm look, similar to the avatar image I used have the yellow problem the worst. Strong, punchy images with a lot of blue suffer less.
swimwivsquid
Re: YELLOW CAST
Post by swimwivsquid »
Hi Bob,
Have you tried a softproof with the profile in Photoshop to see if you get the same cast on screen. I take it you have checked that all the inks are working ok.
Regards
Richard
Re: YELLOW CAST
hi! I know what the PDF is I just did not new that you can print it usuing icc profile.
I can't help yo with your problem as I only have experience with adob3e photoshop. sorry.
PAul
BobC
Re: YELLOW CAST
Post by BobC »
Dear Richard, I don't get quite the same cast on screen but I do get something very similar.
Dear Paul, Thanks. I am tried printing in PS and am getting the result described.
Perhaps I should have been clearer. Two questions.
1/ I have a softness that gives warm images an extra amount of yellow. I need to reduce yellow a little bit and increase blue and black. How would you do that in Photoshop?
2/ I would prefer to print from PDFs. Once I have solved the colour problem in PS I can transfer the technique to PDFs.
thanks Bob
swimwivsquid
Re: YELLOW CAST
Hi Bob,
The way I would approach it would be to have your image in the "soft proof" mode and the adjust the image on screen using levels until its how you want it on screen.Then go back to your normal working colour space ie Adobe 1998 or whatever and then print from that using the ink profile in your printer dialoge box.....
BobC
Re: YELLOW CAST
Post by BobC »
Dear Richard
That is just what I had decided to do. Works perfectly but of course its not really the answer for hundreds of images which are also used for other outputs.
I am fairly certain it is a fault with the Artainium Profile.
Bob
John G
Re: YELLOW CAST
Post by John G »
I had a similar yellow cast, it turned out to be the cyan needed a little clean.
Cheers John
Users browsing this forum: Bing [Bot] and 11 guests
