Epson B1100 print problems
Imme
Re: Epson B1100 print problems
Post by Imme »
I don't work for them or get paid by them but I have got out of "dead print head syndrome" more than once by using this stuff. I guess I've got too many Epson printers lying around!
http://www.ebay.co.uk/itm/ZAP-Cartridge ... 4155bed6b9
JSR
Post by JSR »
Bookmarked, thanks!
Jesus
Post by Jesus »
Imme;34387 wrote:Hi,
awesome! thank you so much. ill give that a go. how does it work? do i fill the carts with it and hit print? As luck has it i got 4 years worth of tax rebate through the door yesterday, fecking amazing timing, so now i can afford to fix the problem!
Ill let you guys know how it goes, in the meantime ill have to use my crappy sx125 and Jet pro sofstretch inkjet paper :/ Iv got a photoshoot booked tomorow for my website, and cant even use the shirts ill be selling, sucks bigtime lol. ahh well shit happens.
John G
Post by John G »
Language Timothy. :wink:
Just for the record, whilst my B1100 miraculously came back to life by itself :-) I dug out my Epson 1400 which had a couple of blocked nozzles and Zapp didn't help in the slightest :-( In fact it's made the problem worse.....I'd already decided to trash the printer but thought I'd give this miracle fluid a go first!
dont trush it just yet Justin!!
Jesus
Post by Jesus »
Hi again guys, well i bought some zap, and as my luck has it, it just made the problem worse, at forst all of my heads became blocked, even after leaving zap in overnight as advised by the instructions, and now it doesnt print a thing, it goes through all the motions of printing but no ink comes out on the paper, i did a nozzle check and got a few lines, not many, but they were all in black! there were no coloured lines? i did another clean and after that it wouldnt even print a nozzle check, its just completely *****d! new printer used about 3 times and broken due to dye sub ink and ZAP, and of course now the warenty is void.
Anybody have any suggestions to this one? lol
Imme
Post by Imme »
Sorry to hear that Justin. Usually a good soak (overnight if needed) cleans my printers out. Don't know if it will help but there's a You Tube video on deep cleaning a stubborn 1400. http://www.youtube.com/watch?feature=pl ... UysQFDH6u0. Never quite get over the amount of ink they find in there:tongue:
Imme
Post by Imme »
Jesus;35550 wrote: new printer used about 3 times and broken due to dye sub ink and ZAP, and of course now the warenty is void.
Are you trying to head clean it with the dye sub ink?
If so this may be the problem if it is of a questionable age or quality, it may contain large particles (lumps).
Try using ordinary inks to clean with and it may just work fine
Jesus
Post by Jesus »
no straight away I bought a bulk supply of normal dye inks and a big packet of A3 jet pro sofstretch transfer paper, then discovered it wont work anymore, yet another £100 down the drain.
