Epson Photo 1400 for Sale (Spares or Repair)
Philipjbaker
Re: Epson Photo 1400 for Sale (Spares or Repair)
@Justin... I appreciate your kind offer. If after trying the suggestions that Spawn has made above it still doesn't work, then I would very much like to accept your offer of a mainboard. I will research this weekend and see if I can find out what the process involves to change one out
I remember something similar years ago with an Epson Photo 1200 it would print half a page then stop. This was using USB connection, yet on Parallel it worked fine, ended getting the printer swapped out by Epson. Does the 1400 have a parallel port, does your computer have a parallel port do you have a centronics cable? If you have all them might be worth trying to see if you can print out a full page. As you can tell I've never looked at a 1400.
Sharon
Sharon
Philipjbaker
Philipjbaker
Justin, may I please take up your offer on the motherboard? Turns out there's no firmware update for the 1400 and cleaning the optical strip as suggested by Spawn above didn't fix it either. Trying to change the motherboard now is the only thing I can try. Let me know about P&P and I'll get it over to you.Justin;39403 wrote:The item should surely have been covered at least to the purchase price, for what little extra this would have cost.I have a couple of useless 1400's here, was thinking about stripping them to try and make one decent printer, pretty sure the mainboards will be ok so if it its something that can be changed easily you're welcome to one
Any idea how they come out? Failing that I'll send you the whole thing! lol.
Philipjbaker
I'm just trying to discover that now....Justin;39421 wrote:Any idea how they come out? Failing that I'll send you the whole thing! lol.
I have a multi purpose printer disassembly module kit here.......BIG HAMMER! lol
Philipjbaker
Justin... turns out it's not too bad, mine is now out. You need to remove the two end covers (2 screws in each) and pop them off. Then remove the back cover that surrounds the metal back plate that houses the power supply and main board. Then remove the 7 screws that hold the metal tray in place and it slides out, you need to remove the cables that connect the board as you slowly pull it out. Have a look at this YouTube video, it's for a 1900 but it's very similar and very helpful. You don't have to strip the printer down as much as shown in the video, just the bits I mention above, as you can see from my pic.
Edit.. sorry put wrong link on, this is the correct one!
http://www.youtube.com/watch?v=JQXG9Qq0 ... pr3Vb85UtK
Here's a pic of mine taken out.
[ATTACH=CONFIG]804[/ATTACH]
- vB_ID:804
- mainboard.jpg (34.34 KiB) Viewed 463 times
- mainboard.jpg (34.45 KiB) Viewed 463 times
Philipjbaker
Haha, I was typing my detailed reply before you posted that, unfortunately I can't use your super module kit, lol.Justin;39427 wrote:I have a multi purpose printer disassembly module kit here.......BIG HAMMER! lol
OK board is out
I see that you have to run a program to get the printer to accept a replacement head....I hope it isn't the same for the mainboard! PM me your address and I'll get it on it's way. Think I'll strip the rest of this 1400 down now...masterclass anyone? Printers under the hammer?
BTW....I hope you labelled all those cables!
