sub dye t.shirt very silly question
jennywren
Re: sub dye t.shirt very silly question
Post by jennywren »
I pressed my first t.shirt yestady supplied by bsm, it printed really well but for one thing which I must of pressed to hard and left a imprint of the press, apart from not applying that much press is there any thing else I can do. If that all there is how can I tell how much pressure to put on. :?:
Andrew
Post by Andrew »
I always used to get press marks on clothing but I just found it part of the process. Once washed or ironed it comes out good as new. Now and then we used to just give a quick press in a few different positions (the shirt not me) which made it less obvious. I guess it's just like iron only part of the shirt which then shows up the rest. If it is any more complicated I'll let someone else give there ideas as I hate clothing and presses........ got some bad memories of vinyl.
supplied by bsm
That driving school gets everywhere these days :)
The press marks are part of the process but as Andrew says, pressing the rest of the t-shirt makes it look less obvious.
I gave up on subli shirts years ago because I hated the press marks around the image. That said, I pressed my first Vapor shirt recently and the lines were hardly visible, so much so that I plan on having another crack at it. Maybe it's because the shirts are thinner, I'm not sure yet. I used to use Xpres and NovaChrome shirts which were much thicker.
accdave
Post by accdave »
Justin wrote:I gave up on subli shirts years ago because I hated the press marks around the image. That said, I pressed my first Vapor shirt recently and the lines were hardly visible, so much so that I plan on having another crack at it. Maybe it's because the shirts are thinner, I'm not sure yet. I used to use Xpres and NovaChrome shirts which were much thicker.
I agree about the Vapor shirts. I use them and Xpres shirts and prefer Vapor.
One tip is to just give the shirt a little sideways stretch when you finished pressing. It does help a bit to get rid of the mark.
John G
Post by John G »
Can you tell me who stocks the vapour t shirt range.
accdave
Post by accdave »
Transfer Press
AJLA
Post by AJLA »
Always use the vapour range now, although more expensive but look mor like a normal t shirt rather than the subli ones.
Unfortunately I don't sell a lot of them, thank goodness we sell a lot of cotton ones!
jennywren
Post by jennywren »
Is there any you can spray on a normat t.shirt that you can subdye on. If so is it worth while doing. Up to know I have only seen four colours to subdye on,
Never heard of anyone succesfully coating to dye-sub, more trouble than it's worth I think.
Obv. you need a light colour. You can get pastels and ringers (different sleeve/cuff colours) but there is a limit.
