Ink issues
Re: Ink issues
Can't find original post :-/ still trying to get colours right on my mugs they seem to be very pale I have used different temps and now I have used a different batch of mugs but the colours seem very pale they seem to be transferred as per printed of so is there anything that I can alter within the printer properties to make the transfers a little darker I am using my new Ricoh printer on xpres Subli paper just wondering if it need tweaking just. Thought x
Re: Ink issues
Are you using the Powerdriver or have you installed a profile?
btw...if you click on your member-name you can select 'View Forum Posts'
Re: Ink issues
Hi me again i am using the power driver could it be anything to do with the program I'm using what program is recommended ??
Ooh thanks for that still finding my way round thought I was going mad
x
Re: Ink issues
If you're using the Powerdriver you can print from any program and end result should look the same. May be worth printing from something else just to double check this though.
Re: Ink issues
Well I originally used Adobe and had the issues above I have since tried using Corel and the results seem to more satisfactory colours are much better
not sure why that would be or if there is anything I can do to improve Adobe as I do like Adobe will have to see how it goes x
Re: Ink issues
Ooh no I haven't see that option I must have missed something :-/ xgorgall2;47255 wrote:Have you selected ceramic in the powerdriver properties?
Re: Ink issues
I don't use Powerdriver myself but I'm assuming all colour management should be switched off in software? Maybe this would explain the differences you're getting?
Re: Ink issues
Try saving the image as a jpg and open in something like word. Does it print okay now? If so then the settings in Adobe are causing double colour correction issues.Chas;47256 wrote:Well I originally used Adobe and had the issues above I have since tried using Corel and the results seem to more satisfactory colours are much betternot sure why that would be or if there is anything I can do to improve Adobe as I do like Adobe will have to see how it goes x
Re: Ink issues
Never could get a top quality result from the Powerdriver and Adobe together, just bin it and use a good icc, no worries about choosing the right settings as with the Powerdriver, just press button and print, as said before, make sure the right boxes are ticked in Adobe, otherwise you will never get the right results, i photographed my set up screens, for future reference, as i know how important the right settings are.
