iphone 5
Re: iphone 5
hi all i am after a template for iphone 5ive tried using the iphone 4 template and resizinf it but donst wortk to good does any one have one or know where i can find one from. i do need asap as i have 20 orders sitting on my desk
many thanks
many thanks
Re: iphone 5
if you willing to send me insert i will do it for you.
PAul
PAul
Re: iphone 5
yes
then i will create accurate templates.
if you need for other phones then you can get them for here: http://www.frames4photoshop.info/shop/f ... at_14.html
Re: iphone 5
I don't understand these type of requests! All you need to do is measure the length, measure the width, and you create a rectangle of the same size in PS or resize/ crop your image to this specific size. It might be worth adding,say 2mm to the measurements to help with positioning the metal on the image but I fail to understand why a template is neededmfarmt85;55364 wrote:hi all i am after a template for iphone 5ive tried using the iphone 4 template and resizinf it but donst wortk to good does any one have one or know where i can find one from. i do need asap as i have 20 orders sitting on my desk
many thanks
- WorthDoingRight
Re: iphone 5
Well templates already exist on the conde website if you are registered with them for their Iphone 5 cases. However like Martin says it does always make me wonder why people struggle with creating a template for items that are predominately a standard rectangle including iphone 4/5 cases and basic mug templates.
- purpledragon
Re: iphone 5
im with you martin why not just scan an insert hey presto instant template that idea is now copyright im gonna come round and check all ya scannersbms;55391 wrote:I don't understand these type of requests! All you need to do is measure the length, measure the width, and you create a rectangle of the same size in PS or resize/ crop your image to this specific size. It might be worth adding,say 2mm to the measurements to help with positioning the metal on the image but I fail to understand why a template is needed
Re: iphone 5
well... you right guys. if we ara talking about square or round item then yes. mesare it and job done. but if blank contains elements like hole tc then some people would like to know exactly where to position graphic
Re: iphone 5
scan insert into ps and then inner area leaving transparent background ,trace, measure actual insert then size insert scan and clip
- purpledragon
Re: iphone 5
paul if you scan the item the hole will be in exactly the right place all you would need to do is place the image to be printed over the scanned image its a lot more accurate than measureing all the elements and making a template .Paul;55400 wrote:well... you right guys. if we ara talking about square or round item then yes. mesare it and job done. but if blank contains elements like hole tc then some people would like to know exactly where to position graphic
Users browsing this forum: Semrush [Bot] and 5 guests
