Epson Stylus WF7015 A3 +
mgibbs
Re: Epson Stylus WF7015 A3 +
Post by mgibbs »
I can get free delivery from BT Busness Direct for you but unfortunately their base price is higher than the one you found.
GoldRapt
Been thanked: 8 times
Post by GoldRapt »
Damn and blast Muttley :-)
regards
Tony
-launching july/august 2026
mel777
Post by mel777 »
Hi
We currently own a A4 Ricoh SG 3110DN sub printer (hassle free thus far and producing great prints). However could you please advise if the ink costs are significantly more compared to say a A4 Epson printer. In addition, I am wanting a new A3 sub printer with good ink running costs and not sure what to buy. Thank you very much.
GoldRapt
Post by GoldRapt »
Hi welcome to the forum.
Maybe your qiestioon will get answered here but seeing as it is covering 3 points I would suggest posting it as a thread of its own and at the same time introducing yourself to everyone, not all members are guaranteed to read this thread.
regards
Tony
pentraks
Post by pentraks »
WF-7015 acquired, some sub ink and blank cartridges ordered, let see whats gonna happen next.
pentraks
Post by pentraks »
Just a little feedback after some time and several dye sub. transfers
My equipment (amateur use)
epson 7015 (NO special color profile)
ink: Sublimation ink for epson printer from a chinese vendor.
Paper: truepix
medium: Rock slates
Heat press: generic swing away A4 Heat press
results: very good to perfect till now. Correct colors, smooth and even trasnfer. ofcourse there is always room for improvement.
Had only once a problem but i suspect what did go wrong (didn't let the print to dry before heat press it)
Only problem is the OEM cartridges that cause problem with ink flow, but now i have acquired a CISS το overcome this...
I will post a photo next time to see by your self
Ang
Post by Ang »
would be interested to learn how things are going using this printer. already have the WF-7015 which i find to be a great printer but now have a heat press, so your findings would be most welcome. have found a uk supplier of the CISS equipment for this machine, which comes empty so would it be ok to fill with sublime inks?
pentraks
Post by pentraks »
Ang;72383 wrote:would be interested to learn how things are going using this printer. already have the WF-7015 which i find to be a great printer but now have a heat press, so your findings would be most welcome. have found a uk supplier of the CISS equipment for this machine, which comes empty so would it be ok to fill with sublime inks?
Hi, first of all i am not a pro but just an enthusiast and everything i produce is for personal use and gifts.
The printer is being used as i commented above and for me its an absolutely perfect combination.
Only thing to take care is to have correct flow of the ink to the printheads.
Ang
Post by Ang »
hi pentaks - thanks for the answer. did you find it easy to attach the CISS system to the printer? and can i ask where you purchased the ink from. Many thanks
pentraks
Post by pentraks »
yes attaching the CISS is a 5 minutes task! about getting ink ask me privately, dont want to make an advertisment in public!
