hello again
its Vera, really enjoyed the show at NEC, now need a epson printer 4880 with 8 inks, any advice please.
also need advice on the best software for improving the digital image, pixels etc
Hello EWveryone It's Vera Here
Re: Hello EWveryone It's Vera Here
Why specifically that printer Vera? Is it the size requirement? They are a very good printer but are cheaper options out there if you are just starting out.
Online
I'll split this topic off into Printers section Vera. My personal experience of the 4800/4880 isn't good. Found it incredibly slow. Print quality was OK but 8 colours is overkill unless you really do have a need for it. I use 6 colours to get better skin tones but for most jobs 4 colours is more than adequate for sublimation.
4880 is a very expensive printer and replacing the inks is a costly exercise!
You'll probably get some good advice from Frisbee on this printer as he is a user. If you're just starting out though you need to consider if you need up to A2 in size. Your next decision is the brand of sublimation ink. You have choices - which brand was being demonstrated at the show?
All depends what software and settings you use as to the speed. It is a very good printer but not needed for most small format subli printers. I have the model before the 4880 as a back up machine.....which I am currently using. Great printer. Mine certainly prints fast enough to compare to other printers I have used. You can also have refillable cartridges rather than cis which is easy.
The Epson 4880 is a VERY good printer, but it can be stroppy, but knowledge is a great thing and we can probably help you.
If you haevn't bought it yet, PM me your number and we could have a chat. If you can cpome to kent then you aer welcome to visit us.
Unless you are going to print 1000's of mugs a week like us, its probably a bit of overkill, but saying that we have printed over 50,000 mugs with ours and I am sure many of the smaller epsons would be long retired by that amount. We have only had to replace the dampers.
Ink suppliers can be a problem, by BMS haev stepped up to the plate on that front and you can't get a better service. Not sure if BMS can supply the printer, if they can they woudl be my preferred supplier for it.
Anything I can help with, please just ask.
David
David
