Mug Image Position
Fordy
Re: Mug Image Position
Post by Fordy »
I've been given an image which is not wide enough to wrap around a mug properly, but it is too big to double the picture up so it appears on both sides.
So I was wondering would you put the image in the center of the mug (parrallel to the handle) or over to one of the sides?
Usually I would ask the customer, but if the customer had given you no particular preference then what would you do?
Obviously theres no definitive answer to this and I suppose you could get away with either I just wondered if there was a norm when it came to this kind of thing.
Heres some pictures of the image and positioning to help explain better
I'd do this front and back, why don't you think it would fit?
Fordy
Post by Fordy »
I use a 539x255px canvas to put the images on (anything wider and I get faded edges) so to double the image up on this size canvas I'd have to lower the height too much.
Russ
Post by Russ »
Image centralised opp the handle, and some text either side of the image to fill the space up to the handle?
10 or 11oz mug? I use 10oz and print 200mm x 85mm
Personally I would center it. But if I could, I would clarify with the customer before printing.
purpledragon
Post by purpledragon »
i must be in a good mood
[ATTACH=CONFIG]1258[/ATTACH]
vB_ID:1258
vB_ID:1258
mug suggestion.jpg (83.81 KiB) Viewed 556 times
jennywren
Post by jennywren »
Russ;57098 wrote:Image centralised opp the handle, and some text either side of the image to fill the space up to the handle?
I do the same, and it looks good
Fordy
Post by Fordy »
Justin;57099 wrote:10 or 11oz mug? I use 10oz and print 200mm x 85mm
Sorry I use 10oz mugs.
Thanks for the advice, it seems going down the center is the general consensus. Adding text would be a good idea but I'm not sure if they want text. I'll confirm it with the customer before printing anyway.
Sorry, I thought we were assuming customer gave no instructions, we could come up with 100 different ideas if you want! :-)
Users browsing this forum: Google [Bot], Semrush [Bot] and 5 guests
