Laser Printer ?
WorthDoingRight
Re: Laser Printer ?
Post by WorthDoingRight »
carter2;57973 wrote:Please don't compare it with Ricoh
Well, the whole point of a discussion is to compare the similarities and differences to educate the masses. At the end of the day it depends on what you are trying to achieve as to which is 'your' best bet.
In my humble opinion there is no real single printer solution as so many jobs require sublimation ink and so many more require 'standard' ink or toner.
I think the consensus of opinion is that for easy of use and acceptable quality printout the Ricohs are best for sublimation, that for laser printers it seems Oki are favoured and for standard ink for t-shirt transfers etc the Epson 'durabrite' printers are favoured. This does not mean that there are not other printer makes that can be used successfully but just what I have picked up from this forum and google searches.
