Vinyl Suppliers List
Online
Re: Vinyl Suppliers List
You could always try http://www.grafityp.co.uk/
They have loads of vinyl and flex for garments and signage. All Siser stuff which from what I understand is pretty good
newsgroupmonkey
Post by newsgroupmonkey »
Hello all. I'm new here and looking for suppliers (other than fleabay which might be an option)
I've been reading the forum for a while (and registered today)
Just so I can get my head around (I'm new to vinyl), I think I'm working as follows:
BMS - http://www.printerowners.co.uk/
MDP - http://www.mdpsupplies.co.uk/
The Magic Touch (TMT) - http://www.themagictouch.co.uk/
BTC - http://www.btcactivewear.co.uk
Xpres - http://www.xpres.co.uk
The Transfer Press - http://www.thetransferpress.co.uk/
GrafityP http://www.grafityp.co.uk/
and another one someone mentioned in another thread... .the Vinyl Corporation - http://www.thevinylcorporation.co.uk
Is that everyone? Any other suppliers anyone might like to mention?
And I take it everyone recommends Flex? Or should I be looking at the flock type products?
I'm looking at (this moment) white on black and black on white.
I'm learning. So I'm probably spouting rubbish. Be patient :wink:
mrs maggot
Post by mrs maggot »
if there is a supplier near you (TMT) perhaps, then arrange to go and visit them - having a local supplier if you are lucky enough to is worth its weight in gold, should you ever run short - dont try and get your fingers stuck in too many pies, most companies vinyl is so close/the same, there are a few exceptions 123 from TMT for instance. But an hour spent in the company of a local supplier will be hours saved in the future.
newsgroupmonkey
TMT are indeed need me (about 6 miles away).
Sounds like a winner then. Didn't realise they had an on-site presence too.
mrs maggot
yes they have a real door you can walk through and everything :biggrin:, just make sure you call them first to arrange a visit, they also hold demo days etc. MDP do as well, and most of the others, but sometimes its down to locality
DANNYD
Post by DANNYD »
Have just received my Cameo, been looking at getting 12" heat vinyl, could anyone point me in the right direction please?
Many Thanks
Ravisteam
Post by Ravisteam »
DANNYD;99621 wrote:Have just received my Cameo, been looking at getting 12" heat vinyl, could anyone point me in the right direction please?
Many Thanks
Hi DANNYD , where do you buy your vinyl for your Cameo ..???...I am bit lost in here as Cameo can have 12 " max most of the rolls are 50 cm ...
Ravisteam
Post by Ravisteam »
Yolo has Cameo size rolls 1.5 M and they are about 8 pounds ..
Dave271069
Post by Dave271069 »
Ravisteam;100787 wrote:Hi DANNYD , where do you buy your vinyl for your Cameo ..???...I am bit lost in here as Cameo can have 12 " max most of the rolls are 50 cm ...
MDP supply vinyl for cameo in sheets 12" x 20"
Ravisteam
Post by Ravisteam »
Thanks Dave271069...They work out cheaper to Yolo ones and also MDP is a favourite one of many here isnt it..??
