Hi
seppo
Re: Hi
Post by seppo »
I have few presses, from coralgraph. Now i need to press 90 x 200 millimeter images and coralgraph press dont press it good on the corners.
Can you help me, i need to buy good mugpress, suitable to maximum images.
Links, pleace...
seppo, finland
Re: Hi
seppo;63769 wrote:I have few presses, from coralgraph. Now i need to press 90 x 200 millimeter images and coralgraph press dont press it good on the corners.
Links, pleace...
seppo, finland
Will increasing the pressure not solve the problem of the edges? How thick is the 90mm x 200mm item?
seppo
Re: Hi
Post by seppo »
Its 10oz mug, increasing the pressure, same result...
Re: Hi
seppo;63864 wrote:Its 10oz mug, increasing the pressure, same result...
Sorry I didn't realise this was a mug. What temp and time are you pressing for and what printer/ inks are you using?
seppo
Re: Hi
Post by seppo »
inc comes feom coralgraph, have no idea of brand. Epson 4-colour printer, S22 i know i could have better one :)
Re: Hi
seppo;63867 wrote:inc comes feom coralgraph, have no idea of brand. Epson 4-colour printer, S22 i know i could have better one :)
We need to know your temp / times please. Lack of colour in the corners might be because of the thickness of the mug, temp, temp & time or pressure.
seppo
Re: Hi
Post by seppo »
i put the mug in cold press, waiting temperature rising to 180 celcius. When it is 180, i pull down a switch and 30 sec countdown to be ready. Thats the manual i got from cg.
Re: Hi
seppo;63894 wrote:i put the mug in cold press, waiting temperature rising to 180 celcius. When it is 180, i pull down a switch and 30 sec countdown to be ready. Thats the manual i got from cg.
i would increase your time to 150 seconds. If colours then look over cooked reduce temp to 175.
seppo
Re: Hi
Post by seppo »
ok, i try that tomorrow
viccar
Re: Hi
Post by viccar »
I have the coral 4 press and ricoh and use 170 and 150 mins.
