Ricoh SG 3110DN How do you set it to Mirror the image?
viccar
Re: Ricoh SG 3110DN How do you set it to Mirror the image?
Post by viccar »
I also use the ricoh sg3110 and powerdriver and it does mirror if you tick the box
JHP
Post by JHP »
The power driver looks a lot different to what i use in the screen shot. Am i missing something because there is no mirror box to tick anywhere on mine?
JHP;64073 wrote:The power driver looks a lot different to what i use in the screen shot. Am i missing something because there is no mirror box to tick anywhere on mine?
When you go to print, do you select the Ricoh SG3110 or the PowerDriver? If you don't see PowerDriver in the list of "printers" then you don't have it installed. Assuming you are using a PC (not Windows 8) then download and install PowerDriver from here:
http://www.sawgrasseurope.com/technical ... c-profiles
JHP
Post by JHP »
Thanks martin, cannot understand why on earth Sawgrass didnt mention this when i phoned them!
Powerdriver installed.
JHP;64079 wrote:Thanks martin, cannot understand why on earth Sawgrass didnt mention this when i phoned them!
Maybe it was lateral thinking - an answer to a question without elaboration!
doe
Post by doe »
can i be having the same problem with a mac and using photoshop cs6
just moved from my epson to the ricoh sg3110dn and i can't get it to reverse image
hope someone can help
