Vinyl Swatches
arko
Re: Vinyl Swatches
Post by arko »
A quick question for hopefully a quick answer... (I cant see that happening on here though! hahaha. :wink: ...)
I was wondering if any vinyl suppliers also supply swatches for particular vinyl brands , like Aslan, Ritrama, Avery etc etc. Or would it be the manufacturer if anyone that would supply them?
See?.. that was quick! :wink:
arko
Re: Vinyl Swatches
Post by arko »
Update:... I just found one direct from MetaMark.... who also have a very cool little app to use on your phone to inform you which colour is which! :)
RogerC
Re: Vinyl Swatches
Post by RogerC »
Supplier will send out swatches. Places like Grafityp, Vinyl Corporation, MDP etc......just contact them and ask. Remember what you see on the 'app' will probably be slightly different to the 'real thing'............IIRC you need a colour corrected screen/monitor to get accurate representations of colours.
arko
Re: Vinyl Swatches
Post by arko »
Thanks Roger... I will be contacting them shortly. :biggrin:
I take you mean digital swatches for the PC?
Are there any firms that could supply physical swatches as well... ones that you could lay down in front of a customer for example?
steve 1
Re: Vinyl Swatches
Post by steve 1 »
arko only an idea if you have any small off cuts cut them into squares and offer what coulers you have to others and if others will do the same for the price of a few stamps you could all have swatches i dont do vinyl it so cant help just an idea
RogerC
Re: Vinyl Swatches
Post by RogerC »
arko;67273 wrote:Thanks Roger... I will be contacting them shortly. :biggrin:
Actual swatches will be sent.....just look around for the brand of vinyl you want to use and the supplier will send a full colour set out. Sometimes it is a set of swatches other times it is like a paint colour chart but yes you get a physical as opposed to 'electronic' set.
arko
Re: Vinyl Swatches
Post by arko »
Thanks guys. And I like that idea of yours Steve. I will have a go looksy to see what I can muster up.... I amaze myself sometimes of how much of a hoarder I am.... Bound to have loads of bits and pieces.
dazzul
Re: Vinyl Swatches
Post by dazzul »
Victory Design will sent you a Jac one.
arko
Re: Vinyl Swatches
Post by arko »
Thanks for that dazzul... have just requested a colour chart and swatch.
dazzul
Re: Vinyl Swatches
Post by dazzul »
I have a local seller of meta mark, does the app work on android ?
