Cutter Setting Question
Suzy Q
Re: Cutter Setting Question
Post by Suzy Q »
Hi
Can somebody help me please. I want to cut some flock (came in a start up pack from BMS for Craft Robo) but I'm not sure whatcutting setting I need on the silhouette cameo. Do I set the 'paper' as : Flocked Fuzzy Vinyl, thickness 28 or as Silhouette Heat Transfer (flocked) thickness 33 ??
viccar
Post by viccar »
Silhouette always reccomend using the lowest setting if your not sure and then working up.
Use the test button then you only waste a small triangle.
Suzy Q
Post by Suzy Q »
Good thinking Batman :)
viccar
Post by viccar »
:biggrin::biggrin: I havn't heard that saying for years.
Suzy Q
Post by Suzy Q »
Must be our age ;) Ok so for future reference it's Silhouette Fuzzy Vinyl (flocked) Blade 3 Speed 3 Thickness 28 :) ...fingers crossed :)
logobear
Post by logobear »
flock is thick and takes a good cutting, a bit less than hologram foil, but a lot more than standard flex.
