no yellow on both printers
Re: no yellow on both printers
hi im new to this forum need some advice if possible have been using a epson d88 printer and artainium inks for some time then left it a while and my yellow stopped working so i bought new refill cartridges and cleaned the heads but that didnt work red black and cyan work fine so decided to try using my s22 so ordered a set of cartridges for it and printed a few things any thing with blue or red was fine but the yellows stopped working in it too and they were only put in today
Hi and welcome to the forum. I'm assuming this is sublimation ink? best advice I can give, you've mentioned that you're using Artainium inks...ditch these printers and move onto a currently supported model. It's the inks that are expensive, you're already paying out for those....and pumping into your waste box so cut your losses.
