I need a template for 12 oz Tapered Latte Mugs
wenico
Re: I need a template for 12 oz Tapered Latte Mugs
Post by wenico »
I've just received my first batch of 12 oz Tapered Latte Mugs.
Could anyone help me out with a layout template for the art work.
I'm usung Corel Draw but can adapt.
Regards
Roy N.
Andrew
Post by Andrew »
I think they have template downloads on Conde.com. You have to register first if I remember correctly. It is fairly easy to make your own by trimming a piece of paper whilst wrapped around the mug and then drawing straight lines down whilst taped in place. Scan the paper after and you have a basic template. You'll have plenty of fun fiddling with artwork to make it fit. Just make sure you charge a lot more for themto account for all the extra work.
wenico
Post by wenico »
Thanks Andrew
Over here they seem to be charging the same amount for a tapered as for a plain mug.
Regards
Roy N.
Andrew
Post by Andrew »
Latte's should be quite a bit more than the standard mug. More expensive blank mug and more work involved designing and changing mug press etc. If you can get it done for the same cost and make okay money then all is good.
try this one and let me know if is any good for you. this is psd template so os for photoshop.
[url="http://rapidshare.com/files/398348669/l ... e.psd.html]http://rapidshare.com/files/398348669/l ... e.psd.html[/url]
wenico
Post by wenico »
Thanks Paul
Regards
Roy N.
jaffacat
Post by jaffacat »
DO you print them in the mug press you do your 11oz in? Do you need a special wrap (silicon wrap to go around them) how are you finding it?
Thanks Lisa
You'll need a special conical shaped heat element - there are 2 of these supplied with our DF14 mug press for the large latte and smaller latte mugs.
