New product design software - Demo Video
Re: New product design software - Demo Video
This is a snapshot of product images available ;-). Flat iPhone cases no problem.
Hi Justin
Will the problem of a white background be fixed?
I exported the image from Corel as a JPG and a PNG both with no background, but when I imported it there is an obvious white square. The image gives you a good idea of what I mean.
[ATTACH=CONFIG]1899[/ATTACH]
vB_ID:1899
vB_ID:1899
Did you export this as a png with transparent background? Just had a go with this myself.....I see what you mean with the white background but saving as a png with transparent background worked fine :-) As your image has a white background it will take that and place it on the mug.
Exported as a PNG from Corel version X3 (I have X5 but never bothered with it!)
No background and exported as RGB
Is it possibly due to it being a mug and the software is not complete yet?
When you say no background, are you selecting transparant? Otherwise it may be defaulting to a white background.
Hi Justin
Ignore my posts about this. After a bit of playing around I have found out that the DLL's on X3 are faulty. A quick reinstall of them and all is fine.
No worries ;-)
jampers
Post by jampers »
Will this work on a Wix site?
I believe it can be built into pretty much any type of website but I'll check this particular one for you.
jampers
Post by jampers »
Justin;76001 wrote:I brown it can be built into Pretty much any type of website but I'll check this particular one for you.
perfect, thank you
