VINYL SIGNS
NASH
Re: VINYL SIGNS
Post by NASH »
anybody doing vinyl signs.
i`ve got a robo cutter and was thinking of doing vinly signs for shop windows for local busineses.
What do you think is there money in this ?
R.Prints
Re: VINYL SIGNS
Post by R.Prints »
Hi Nash,
I have a Robo and do shop/vehicle decals. There is a market for it as long as the price is right, sign shops offer fitting as well which some customers want, also the largest print you can cut is approx 7inch which is good enough for cars and most windows. Ps - Remember if its for the inside of a window to cut mirrored.
Good Luck
Ray 8-)
NASH
Re: VINYL SIGNS
Post by NASH »
so what do think we should charge
R.Prints
Re: VINYL SIGNS
Post by R.Prints »
Depends on the size obviously. For 1mtr cut at 7in I charge £20 approx, depending if its going to be a repeat order.
NASH
Re: VINYL SIGNS
Post by NASH »
my robo only cuts A4 so am i right i will be using 3 sheets of A4 and then the application tape
AJLA
Re: VINYL SIGNS
Post by AJLA »
Hi Nash can you not alter the length of the sheet to cut much longer. It makes it a lot easier if you can rather than making jigsaws out of A4 lengths.
R.Prints
Re: VINYL SIGNS
Post by R.Prints »
Hi Nash,
Output settings 210 x 1000mm will cut one strip, I think if you tick the TILE box in output settings you can keep going and do longer lengths, but havn't done it yet.
NASH
Re: VINYL SIGNS
Post by NASH »
well i never knew that Thnks
i`ll try and experiment, you live and learn every day
R.Prints
Re: VINYL SIGNS
Post by R.Prints »
Life and Forums are always a learning curve.
Good Luck
Ray
NASH
Re: VINYL SIGNS
Post by NASH »
just thought how would i cut 1 meter lengths.
would i not need 1 meter carrier sheets
