sheilds wooden and metal sheilds
Re: sheilds wooden and metal sheilds
I'm looking for plaques, shaped like sheilds, I would like metal sheilds if thats not possible where can I get them cut
and then I can put them on a sheild shaped wooden bases, also where can I get them. I need about 50 of each, not to fussed on size only not to small or to big. Can any one help. Which metal (colour) would be the best to use. There would be no metal showing but need to show the colour of the design to the max. Sorry is this sounds mish mash. Hope you can help
What about these ?
[url="http://www.thetransferpress.co.uk/acata ... ields.html]http://www.thetransferpress.co.uk/acata ... ields.html[/url]
I did a square and printed out the size of the sheild, these are to small need double the size, abut 4 inches or slighter bigger then the wood sheild will need to be 6 inches, it that makes sense. Thanks for your help
We had some new wooden shields come into stock on Friday. These have a white printable face to them and from memory are about 5" wide by 7" tall, but I'll need to confirm this when the office is open. They have a mahogany coloured edge to them.
I think I know which you mean but the ones I had did'nt hang right or was diffcult to put up. Do you have these on your site for a look. Thats why I'm trying for the metal sheilds and possible buy the wood bases from a trophy wholesale. The size is perfect.
We don't have them on the site just yet as they are new products that only arrived into stock on Friday. They have a cut out groove on the reverse of the shield for wall hanging.
I've just had a look but I've these before and they take a image really well but trying hanging of the them on the slatboard is hard, so I still need the metal sheilds and the wooden backing, but thank you for trying to help, its much appreciated.
Is it possible to print on the small metal sheilds then put them on a slighter thin wooden sheild, then attach them to together, then use a another wood sheild to get the effect that I require
, I know now where to the metal sheilds thanks to accdave.
