Webbing
Re: Webbing
Hello everyone
Just wondered if anyone had tried sublimating onto Polyester webbing, and what results you got from it?
Also I notice that webbing normally comes in either polyester and polypropylene - does polypropylene take sublimation print well?
Re: Webbing
Well I got a metre of polypropylene just to test it, and it doesn't take sublimation at all (and I was afraid it might melt in the press). I guess I'll just try the polyester webbing when I can get some and see what happens.
Re: Webbing
What kind of webbing is it?... Fishnet size?... deniere size (womens tights... coorrrr! hahaha)?... Im not sure about webbing and its properties but I would have tried maybe transfer (Print and contour cut to get rid of most of the backing?)... hmmmm. Although the heat maybe a problem (can probably be sorted with some good Teflon sheeting), the real problem I think lays with the hole size. Multi-colour, single colour, layered vinyl etc etc... Can you maybe post a pic of what you are trying to achieve?
Re: Webbing
I was looking into making belts with customised designs. I'm not really sure it's possible to achieve, but just researching it.
soulclaimed
- squashynose
Re: Webbing
I know this is an old thread, but polyester webbing is very much printable, although it shrinks quite a lot, so you need to preheat it for a good 20 seconds. But it gives great results, an example:
https://scontent-b-lhr.xx.fbcdn.net/hph ... 1050_n.jpg
I only printed one side, but obviously both could be done if you wanted
Using Ricoh SG3110DN printer, Sublijet-R inks, and rubbish cheap heat press from Coralgraph!
Bespoke pet accessories, by Leading the Pack
Re: Webbing
very much printable
[ATTACH=CONFIG]2249[/ATTACH]
- vB_ID:2249
- komiks.jpg (91.8 KiB) Viewed 522 times
soulclaimed
Re: Webbing
they look great glad i ordered some belts to test now although not paid for them yet as the transfer press don't allow online payment :/ unless people know where else to get them?
soulclaimed
Re: Webbing
what temp and time would you recommend, im getting reasonable prints on the belts with 350f and 140 seconds but is there a better temp and time, also paul how did you print the whole belt with no white bg without it leaving gaps?
Re: Webbing
i print it 180C for 70sec.
and to print large you need large press
