cut vinyl sticker application instructions
Offer your services/products to other members here or post your requests
windyash
Re: cut vinyl sticker application instructions
Post by windyash »
Hi , Ive recently been selling a few cut vinyl stickers on Ebay and also to people coming into the office, but I think I should include some instructions omn how to apply them. Im not very good at explaining things on paper so wondered if any member on here had some instructions I could look at and maybe alter to suit my needs?
I know its a bit cheaky but I tried last night and came up with a whole a4 page that is just too much and cant imagine people reading before attempting to fit sticker!!
Mimaki CG60-st cutter , Ricoh 3110 sub printer , OKi laser , Epson inkjet , 2x heat press , mug press , cap press, Flexisign pro and coreldraw X6..............and learning ...........
and now a Roland SP-300v Versacamm !!!!!!
mrs maggot
Post by mrs maggot »
this is on ebay, and there are lots of instructions on the net - just use google as your friend
http://www.ebay.co.uk/gds/Die-Cut-Vinyl ... 869/g.html
decarbon8
Post by decarbon8 »
[FONT=&amp] I send out a copy of this with decals I sell, you can use it if you want.
APPLYING YOUR DECALS[/FONT]
[FONT=&amp]Your graphics will arrive sandwiched between two sheets.[/FONT]
[FONT=&amp]Transfer tape and waxed backing paper.[/FONT]
[FONT=&amp]
I cannot stress enough how important it is that the application surface be free of all dirt and wax.[/FONT]
[FONT=&amp]Clean your surface THOROUGHLY.[/FONT]
[FONT=&amp]With the backing paper still attached position the graphic where you want it applied. Stick a piece of masking tape on your graphic anchoring it in place. Once you are happy with the positioning lay a line of masking tape along the top edge of your graphic.[/FONT]
[FONT=&amp]Raise the now secure graphic sandwich and slowly remove the backing paper from the vinyl and application tape.[/FONT]
[FONT=&amp]Carefully lower your graphic to the surface using a squeegee to remove any trapped air bubbles.[/FONT]
[FONT=&amp]Complete your installation by carefully removing the application back against itself. Small air bubbles should be popped with a pin and press out. [/FONT]
mrs maggot
[FONT=&amp]secure graphic sandwitch
not all witches play in the sand, most are busy flying broomsticks and getting hungry enough to eat their SANDWICHES !!!![/FONT]
decarbon8
Post by decarbon8 »
lol I did just type it up quickly now edited :)
mrs maggot
Cool, it just read that you posted that one out, and here was a copy of it, so worth pointing out, if that was what you had been sending out.
windyash
Post by windyash »
Cheers , hadnt even thought of Googling it!!! Had a stressful few weeks so just ignored the obvious !!
All sorted now , Thankyou
