Ricoh SG3110DN colour issue
Re: Ricoh SG3110DN colour issue
Well I tried uninstalling powerdriver and then installing the icc from sawgrass Europe website and making all the changes to colour management and print settings for CorelDraw x6 etc and the results are the same, the colour is not printing correctly
Matthew
photo's are coming out ok it just seems to be when I select colours when typing text (from the colour pallet on the right or typing rgb code)
Photo of insert does look dark but that's as i'm just using my phone camera
- vB_ID:2698
- autumn-89183_1920.jpg (92.35 KiB) Viewed 223 times
- vB_ID:2697
- WP_20140428_15_40_35_Pro.jpg (90.45 KiB) Viewed 223 times
Matthew
Can't remember which user it was, but they said they got better colours using the ICC with Photoshop managing colours compared to using power driver.
If all PD does is select the Sawgrass ICC and apply it in some way, then the question is more whether or not Photoshop is better at colour management and processing than PowerDriver.
Conde in USA (from reading their posts on T-Shirt Forums) seem to be creating their own ICC profiles for the Ricohs, and recommend users use these instead of Sawgrass' own ICCs or PowerDriver - read into that what you will.
I'd recommend using Adobe RGB (1998) as your workspace profile rather than sRGB. If you set any other equipment to this workspace too (scanner, camera, monitor) then you'll have a bit more of a consistent workflow.
Since installing the ICC I have changed everything to Adobe RGB (1998) that it tells me in the sawgrass guides,pisquee;87353 wrote:I'd recommend using Adobe RGB (1998) as your workspace profile rather than sRGB. If you set any other equipment to this workspace too (scanner, camera, monitor) then you'll have a bit more of a consistent workflow.
Matthew
Well I've heard back from sawgrass again and they have just basically said they don't know sort it yourself.
I have tried both powerdriver and ICC with both CorelDraw x6 and photoshop cs6 and I still get the same colour problems no matter which way I use it.
I just get the feeling that both sawgrass and supplier don't care
I've never had a ricoh before so don't know where to go from here apart from smash the stupid thing lol
Matthew
Make sure that when creating new documents, or loading in old ones, that they are in Adobe 1998, as I have had problems with Photoshop seeming to forget my choices, and not converting on load/import, and not having 1998 as default when creating new file
yeah all these settings were entered, it evens warns me when I import a image saying it doesn't match colour then asks to me f I want to convert and has option selected as adobe 1998 for me (it's in the guide from sawgrass)
Matthew
That's good - remember to check if it suddenly stops asking you (which is what I have had happen!)
I'm going stay using CorelDraw x6 as i'm not a fan of photoshop
Matthew
