Brand New Here
FrankieRudd
Re: Brand New Here
Hi all - another wet behind the ears novice here
I SO wish I had found this site before I bought my ebay bundle - unnamed ink, unnamed paper, mugs are ok - and the longforte stuff I have had is ace - as is the actual heat press and mug press! PixMax?!
No idea of ICCs, or priming the ink cartridges if your pants printer cant recognise the cartridge ... until today!
A selection of mugs and the printer very almost found themselves coming to an untimely end - albeit fairly colourful!
Just glad to have now found the site and from what I have read so far, a lot of very helpful members!
Good to be here!
Frankie
Good to be here!
Frankie
Re: Brand New Here
Hi Frankie and welcome to the forum
I'm sorry you didn't find us sooner but at least you've landed in the right place now! I hope your initial issues haven't put you off sublimation and we look forward to getting to know you more
DSF Admin
DSF Admin
dustedpetalsx
Re: Brand New Here
Welcome!!
I bought the Pixmax bundle too - how do you find your mug press? I'm having some problems with mine and wondering if I should have invested a little more!
Re: Brand New Here
Anyone have experience with the PixMax 38x38cm Flat Swing Heat Press? I saw it today at a pretty high discount (44%) on eBay: http://www.ebay.co.uk/itm/PixMax-38x38c ... 4869c7d0b3
The website of the seller "monster-doodles" shows they have a new model (probably to replace this one) also at a pretty good discount but a bit more expensive than this one. Is this a reliable seller?
DJMarkland
Re: Brand New Here
Hi all, the boss bought a Pixmax mug Bundle a while back and it had been fine for me. We went and bought the Pixmax heat press too. I had a problem with the heat element of the mug press (my own fault) and Monster Doodle were fantastic help.
I know its not the best kit on the market but for us its perfect
Re: Brand New Here
Does the PixMax heat press give fairly even temperatures on the whole upper plate without any great oscillations between the center and the edges?DJMarkland;97063 wrote:Hi all, the boss bought a Pixmax mug Bundle a while back and it had been fine for me. We went and bought the Pixmax heat press too. I had a problem with the heat element of the mug press (my own fault) and Monster Doodle were fantastic help.
DJMarkland
Re: Brand New Here
Hi Gilsan, Yes it does give an even pressure but you must ensure that the base of the press is level otherwise the whole press will shift. I cocked up a jigsaw or two before realising one 'leg' wasn't even touching the desk!
Re: Brand New Here
Sounds like you the new faces are experiencing the world of sublimation in the normal "Woops" "Ahhh" "Ohh I see" "What!" "Argghhh" "Wayhay" etc forms.
The thing is just as you have it sorted....you won't!
Welcome aboard folks have fun....and if something says "FREE"....read the small print because it probably isn't!
Janners
Janners
