Help Needed please :-)
North guy
Re: Help Needed please :-)
Post by North guy »
Hi all you geniuses!
i am having trouble creating a template that i can save and use over and over again for the metal car signs that BMS sell http://www.printerowners.co.uk/sublimat ... g-sign.htm
would anyone be willing to make me one?
i would of course pay for this kind gesture :-)
any help would be greatly recieved
Griff
If all you need is a template in photoshop then simply create a new file measuring about 3mm wider and taller than the piece of metal and save it as a blank template. What more are you after?
North guy
Post by North guy »
bms;89005 wrote:If all you need is a template in photoshop then simply create a new file measuring about 3mm wider and taller than the piece of metal and save it as a blank template. What more are you after?
hiya, thanks for reply, yeah just a photoshop template but I can't find how to create the diamond shape, I know I'm probably being thick lol
Griff
galerion
Post by galerion »
Its a square 15.3cm x 15.3cm then just rotate it.
Or for trickier shapes, put them in your scanner, and then yo have the shape to make the template, just check the dimensions are still true once into PS.
