Needing a good transfer paper
Discuss other print methods.
daxus
Re: Needing a good transfer paper
Post by daxus »
Hi i currently make bags with images on and ive been using a standard transfer paper and applying it with a iron we are getting a heat press in september but untill then im stuck with the iron my roblem is that my customersare reporting that the transfer is peeling a few days after they started using it i was hoping some one could suggest a good transfer paper i can use with these tools ive tryed vinyl sublimination and thought it worked great for my item but my suppliers havnty been very reliable im experimenting with fusible cotton but any ideas would be great, the images are usually photos or art work i have tryed 2 or 3 standard transfer papers and varied the tempretures but i really need a reliable product until i can get the heat press in and subliminate the items thanks
NASH
Post by NASH »
have you tried this, i`ve used this on t shirts
[url="http://cgi.ebay.co.uk/T-Shirt-Transfer- ... 45f45d80f3]http://cgi.ebay.co.uk/T-Shirt-Transfer- ... 45f45d80f3[/url]
daxus
Post by daxus »
yes thats the exact one ive been using i check the bags before they go out ,always stuck down few days later ppl saying its lifting i think probably because its a bag and there is alot of movement
NASH
Post by NASH »
well i`ve done many t shirts, but mind you i`ve been using a heat press
daxus
Post by daxus »
maybe this makes the difference roll on september lol
Kaz
Post by Kaz »
It's the iron that's the problem, you're not getting enough pressure on with it.
When you get the heat press, it will be much better :)
