Trying to find a solution for iphone blanks corners... We can do it! :-)
3D Sublimation
ArtyGamer
Re: Trying to find a solution for iphone blanks corners... We can do it! :-)
Post by ArtyGamer »
Mine is 0.08 too, which pretty much means there's no air in there at all. You can't really get much more pressure than that unless you start messing with your vacuum pump.. but you don't have to. If I get good results with 0.08 pressure then you should too.
membrane
Post by membrane »
asfasf;90181 wrote:But how can you get more pressure? Mine shows 0.08. What about yours, guys?
I'm at 0.8 I believe. My machine was fitted with a vacuum regulator knob at the factory. I had bought the machine and a small frame to do cases with film. The machine never produced good cases with the film.
membrane
Post by membrane »
Can't download the templates...
membrane, you do not have permission to access this page. This could be due to one of several reasons:
  1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
  2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
asfasf
Post by asfasf »
membrane;90185 wrote:IThe machine never produced good cases with the film.
What problems do you experience with the film? I tried it without any frames and it was pretty ok. The only problem was the front edges but I had the same problem with paper.
membrane
Post by membrane »
Most problems with film is the stretching/warping and the sides not getting enough color. Lots of fading on the corners/sides especially with blacks. Not to mention the film costs $3 every time I sublimate (4 cases at a time).
I use a completely different machine when I use film.
asfasf
Post by asfasf »
Well, I do not have any stretching/warping problems with film when I use it in a membrane press like this. I have them when I use it in a film only machine though. May I ask you what machine do you use with film?
membrane
Post by membrane »
I don't use film with the membrane only paper, I tried to use it that way but too many problems. The film would bubble when I lowered the membrane. I could never get a good solid print.
This is the machine to what I have to do film only (my machine has different graphics on front)
[ATTACH=CONFIG]2872[/ATTACH]
I also have the same red machine everyone else has with the membrane to do paper.
vB_ID:2872
vB_ID:2872
Davalos
Post by Davalos »
arty, thank you for the tips, from across the pond and the continent! (I'm in LA) A question: How tightly do you tape the paper onto the jig? do you leave some slack or is it super tight against the case/mould?
